ABS
Barron
  Turbo S,Exige,R5,182
Im looking at sorting out the ABS with my conversion would this work?
172 FF ECU
172 FF front hubs etc
172 FF rear axle
is that all i need for the ABS to work or is there anything else required
thanks
carl
Barron
where abouts is that stuff and i suppose they are different to the 1.2 abs stuff? :p
Depends how yoor going about it do you want to keep your ABS computer oe chnage the rear axle etc?
You can just get the rings made up to use any combination of ABS and husb etc. UCH arn't factors with the swops anyways .
Barron
The front and back are front the same car and have the same amount of teeth.
ABS computer? :S
/carl
ABS computer? :S
Ok then use the Abs computer form the 172 for simplicity.
Engine is best out to swop the ABS if you are swopping the engine not a bit by bit swop etc.
