I think its set down between the radiator filler bottle bit and the airbox. Its a fair size unit with ABS written on it and if you had it you would see it as soon as you pop the bonnet. No pics though but i can remember one being posted before on here!
a large unit bolted at the back of the engine bay near the gearbox.it has a lot of thin metal pipes attached to it and a wiring loom going to it.also if its got abs then the warning light should appear for 2 seconds when the ing is first switched on.
