Abs ...
Hi I have a 182 and am taking it on track this year !
The abs is very sensitive and I find am loosing A lot of braking force ! I have uprated disc and brake pads and have also using high performance fluid !
Is there a way of turning the abs of completly?
Am using Toyo proxies 4 tyres
The mintex front grovved disc and pads ..
I was gonna get a set of 4 pots? Do they make a lot of difference
To be honest, it sounds to me like you're either too aggressive under braking or not braking in a straight line perhaps. Or theres something not right with the car..
Not calling you a sh*t driver, but I've not had much of a problem with the ABS on these clio's before under hard braking.
I am aggressive on braking ... I live in the welsh country side so there ground conditions isn't great ?
What pads could you recommend to have more of an aggressive bite to them
Depends, because the more performance orientated you go the less bite from cold you tend to get.
DS2500's are a good fast road pad, DS3000's are mega on track as are CL's Rc5's & 6's.
Yeah it's my daily so I think ds300 be there ones .. Thanks for your help
If you do a lot of spirited driving/track days then you can't go wrong, couples with hoses & some decent fluid you're on to a winner.
