Adding ABS
  Ignis Sport
I have one of the base model clios which doesn't have ABS, so i am wondering if it would be possible to add ABS to my car as i am thinking of a engine conversion later in the year.
Cheers for any help
Jamie
Yup, if you transplanted the entire running gear of a car with ABS.
TBH it would be easier to buy a car with abs fitted.
You could do the abs yep its way to much work to be worthwhile realy the system is stand alone but you do need a few bits and pieces.
Forget it if you realy want it when you ado chnage the engine (and ECu/looms etc) you'll also use that doner ABS etc abs sytem for similicity.
