Additional air feed
on a mark one with a standard air box, hot air feed from manifold has been removed. can i now just place a piece of piping from the front bumper into this? or do things need to be cut etc?
  Skoda Fabia vRS
jus put some pipe into it
however, there is like a thermostat flap on the air box so you would have to gut that out to get 2 genuine feeds, otherwise one will be shut all the time because of the flap
ok i presume this is to stop hot air coming in from the manifold whilst its funning.
how do i get this out?
  172 cup,s2 rs turbo
the flap is just between the main air filter box and the air pipes.pull of the pipes and have a look.you will probably be able to just prise the flap off.
  Skoda Fabia vRS
take the air box off and open it up, if you cant get it out easy enough just attack it with a hammer an chisel or even a drill......
to get the air box off do i have to undo the 3 bolts at the top? if so mine are rusted and it aint coming off in a hurry
