Adjustable Fuel Pressure Regulator
Chambers_RS
Car  Clio 172 Cup&Leon K1
Anyone running a adjustable FPR?
I’m in the middle of fitting a swirl pot set up and going run the return hose through a AEM FPR but currently have nowhere to take the vacuum pipe from.
I’ve spoken to @robzracing and he doesn’t run a vac pipe to his.
Just wondered if anyone does and where they get the vacuum from?
I’m tempted to try teeing into the brake servo vacuum pipe? Will this work?
I’m curios to know this as well. Would like to run a FPR, whilst upgrading my injector fuel rail and all fuel lines to Teflon coated e85 spec.
as longs as its mapped for either static fuel pressure (might aswell on n/a) or fluctuating pressure itll make no difference. take the easiest route and don't add a pressure ref line (y)
Cheers bud.
Do you mean just run the return straight to the swirl pot with no FPR?
