Adjusting Xenon lights
Car  Clio 172 Ph2
Anyone know if this is possible on a Mk2 172?
I understand theyre supposed to be self adjusting but mine seem to stop too close to the car since ive had it lowered and filled the boot up with ICE.
I can only see a little way infront of me when its dark and its dangerous!
You can with a long phillips screw driver. There are white plastic turrets at the back of the lights that adjusts the height of the beam on the back of the light unit. Obviously find a dark flat road or carpark. Don;t adjust too high as it will cause glare for oncoming traffic.
Quote: Originally posted by Tomclio16v on 03 November 2003
careful remember to walk away from the car quite abit
And make sure there are no TWOCCERs about.
Hmmm... think I adjusted them a bit too high. Had an aeroplane try and land on my car ;)
there is info in haynes about doinbg it properly - park certain distance from wall, measure distance up wall etc. bit better than doing guessing
