ag srp and egp
  Ph1 172 + Combo van
i'm going to look into buying some of this as it seams like a winning combo from what i can hear on here but one question i want to ask is how easy are they to buff off? and for the extra gloss protection is it best to use an applicator pad or just some mutton cloth to apply it. then buff of with a microfibre? thanks
also how many times can i do my clio with a 325ml bottle using it quite lightly?
I use applicators for both. SRP left to dry for a few mins and buffed off. I Leave EGP about half an hour before i buff off.
Both buffed with a soft Microfibre cloth.
  16v Dynamique
As said, less is more, especially with the EGP as it is a pain to remove if you put it on too thick. Don't let it bake on in direct sunlight either!
MRBILLYUK
  FF Jeden Osiem Dwa
I apply the srp with the german applicators , you get a bit of bite with them . Better than the microfibre applicators for polish imo .
http://www.cleanyourcar.co.uk/accessories/sonus-sfx-pro-applicators-pkg/2/prod_31.html
For the egp i use the small round yellow applicators . And for waxing the microfibre applicators .
  106 GTi
I apply them both with foam hand pads and remove with microfiber cloths.
You need to work the SRP until there is little or nothing to remove or it will dust.
The EGP needs to be applied as thinly as you can and then it is probably to thick. If you are in the shade the longer you leave it on for the easier it comes off.
325ml of the EGP will last ages, not so long for the SRP, but a fair few uses out of a bottle.
  Ph1 172 + Combo van
yeh cheers for the replies guys i dont plan to use the polish as often as the wax so 325 should be a good amount. cheers!
