Air Con blowing warm air !! 2003 172
Turned the car on tonight and the air con is blowing but not cooling , the fans working I can hear the compressor kick in and the system is at the normal pressure , what else could the problem be ?
cheers
lad25
  Volvo S60 T5
pressure gauge???
You got me baffled, have you had it on a Aircon machine to check high and low side running pressures, 25psi is not good on a high side which should run around 4 or 5 bar.
Normally when the AC system is gassed ok the external temp sensor is at fault.
lol I had a pressure gauge on the low pressure port of the ac pipe and it read 25psi . How much will a garage charge to fit a new sensor ?
is it the same sensor as this extract from a megan o&m ?
mike means the external temp display on the bit with the clock/radio display!
if thats showing ok, the other thing is has it ever had a aircon service/re-gas etc??
