Alarm problem on 172- going off all the time
Car  172 clio ph1
Right it happened a bit before but not to this extent. Its been going off all afternoon, now I have managed to work out its interior sensors but nothing in there to set it off. Even looked for flying creatures seeing as its warm.
I have managed to set it at the moment with no interior sensors but is there away I can lock it on a regular basis without the alarm set with the remote???? as to be honest my neighbours are starting to get a bit fed up with it.
Also I am taking it that deactivating the interior sensors is something I have to do EVERYTIME I get out the car if I want to leave them deactivated.
Thank you in advance.
Btw I searched but mostly came up with 182 alarm issues.
Well sorted it, moved all the internal sensors and since then it hasn't one off again. Not sure why it was doing it anyway, may have been the heat I guess.
As I had a pm about it I thought I would add this here. To deactivate the internal sensors when you want to leave a dog or kid or mate in the car, you before getting out turn the key to the on position seven times, then get out and lock it as you would normally. If it is done right the led lights up solid for about 40 seconds.
