Alignment Long Eaton
  182 Cup
So my cars getting the air removed from the abs pump hopefully tomorrow, and then I need to go straight somewhere and get it aligned as I've changed TREs, ball joints , shocks, springs and steering rack bushes. Which is likely to see it a fair way out.
Ideally just want somewhere to get the alignment pretty good and the steering wheel straight, under £40 as I'll be brassic after paying Mick and payday is Friday (dammit)
Pep
  M2,XJS,S1000RR
Best place to go dude would be McEwans garage in Derby, he's an Alfa specialist but has the best kit anywhere local and does a proper job.
Will be more like £70 but well worth it - proper perfectionist.
He did my M3 and was literally like a different car even though it showed ok at ETS in Derby.
Pat 182
  cliosport 182
Spot on there Joe with McEwans ;) Im prity sure Mick as a place in LE that he uses when hes put BC's on cars?!
Pat
Pat 182
  cliosport 182
01332 342682 Mcewans mate sat morns I think?? Shaftsbury street them 1st units on the right hand side through the gates :cool:
Pat
