Amp keeps going into Protection mode?
Car  Clio DCi 65
My amps keep going into protection mode when i play my music for about 30seconds!!
Does anyone know why this is happening and how it can be fixed?
check for loose conections in your powerlead-at bat and at fuse.
it could be your sub itself that is dodgy, but not very likely (happened to a mate)
im having the exact same problem i think, my amp will cut out after about one minute. i hav had 2 amps in an both do the same thing.
spent ages trying to find out whats wrong so now im going to take everything out and put it all back in with a different wiring kit
There are 5 things that protection circuits on amps will detect.
1. Short circuit on the output
2. Low volts on the supply
3. Overvolts on the supply
4. Overheating power transistors.
5. Overdriving the input stage.
1. and 4. are easy to detect.
3. Is highly unlikely unless your alternator control has gone wrong. you would know anyway as bulbs would start popping.
2. and 4. are the most common cause.
Low voltage can be as a result of the battery being less than able to handle the cars electrics and the additional load of your loud music.
Check this by putting a meter across the battery terminals, with the engine at tick-over it should read 13.8 volts.
Now do the same check at the amps supply terminals. should be within 1-2 volts, depending on the cable run from the battery.
Turn on the system and check voltage drop.
(When you test the system dont crank it up, just run it at sensible levels with something other than drum and base, garage, grunge rock or any of that heavy base stuff)
Check the voltage at both the battery and the amps supply terminals again. If you get near 10 volts, the protection circuit will probably cut in.
Thats deliberate set to save your speakers having raw DC shoved down them.
You will need to look to your battery and wiring to correct this.
Maybe a new higher capacity battery (see if the diesel version of your car battery will fit) and maybe have the alternators output checked. You need a specialist to do this, a good auto-electrician if you can find one. Lucas or L.UK as they call themselves now will do this for you..
4. will show itself if you are overdriving the input side as in :-
5. Some head units will have as much as 3v output and a lot of amps wont handle this level in. so if your amp has an input adjustment, turn it right down and this may solve the problem. You wont get any more output by over-driving the input...just problems.
When you have established where the problem is, you can set up your system for the maximum it can achieve, NOT the maximum you need, if its not capable of any more QUIT where its working.
Its like expecting 200mph out of a 1.2 Clio. Nice, but you will never get there.
yeah i'd say it would either be a bad earth(most likely) or a stray wire somewhere
Hmmm,
Il have 2 rewire it all wen i get it back from the garage!!
Does anyone know what a tdi censor thing is?
Cars gotta hav that done and if it dont work its got summin 2 do wit the injectors!!
Im tampin
You can check the earthing by simply making sure the cable is at least equal in size to the power supply cable and is grounded properly to bare metal close the amp.
Its possible that this could cause the problem but its glib to just say that without knowing the rest of the system is sound.
Thats the problem with "experts" conducting remote diagnostics.
As far as your other question, are you sure they didnt say "TDC sensor" which is part of the tuning and emmisions control system ?
yeah but i've seen cables grounded to bare metal but still not a good connection.
well what else can you do apart from a remote dianosis(well he is only about 15 miles from me but thats besides the point)? copy and paste something from another forum?
ahhh yeh a TDC Sensor thats the one!!
best not b too expensive or wont be gettin a pug for xmas !!
Whats a remote dianosis?
Where in south wales u from n how much those lights cost? Look lush!
Wahay!
Got a hole new sound system today!
JBL 12" Sub n JBL 600watt amp and its wiring kit for £40!!
Absolute bargain n it was all in mint condition!!
FreeAds is the best lol
