andy_coops - Iceberg 172
andy_coops
  172, VRS, Clio 5
Thats a bit crap but at least you are now home.
Car really does look amazing mate šŸ‘ŒšŸ‘Œ
Thanks mate.
We had a bit of a giggle as we both expected the 182 to break. He’s had a few issues since he bought it and it ran smooth as today. Highlight was me saying ā€œit’s brokenā€ over the walkie talkie - proper TG moment šŸ˜‚
andy_coops
  172, VRS, Clio 5
Photo of the day - my old nail was in pretty cool company šŸ˜Ž
andy_coops
  172, VRS, Clio 5
New Valeo coilpack fitted today. All leads checked and cleaned with contact cleaner. Not the most exciting update but it should cure the hesitating and cutting out. Car idling fine anyway.
  172
This is an awesome read from start to finish!! Ive gone the opposite direction to you and i started with the floor and rear end and now just pulling the engine and box out to do the engine bay etc
Its taking a while but will be worth it in the end and need to update my thread on here tbh its been far too long!
Keep up the good work its looking awesome!
andy_coops
  172, VRS, Clio 5
Thanks mate šŸ‘ labour of love most of the time lol. Looks like more lockdown projects will be started soon šŸ™„
jameswrx
I’d also be inclined (if you haven’t already) to get into the fuse box in engine bay and remove and clean up all relay connections and fuses. Seems unlikely a bump cut it out because of leads.
My money would be on a relay shutting things down going off mine having a similar issue before. Gave the fuse box a prod when mine wouldn’t restart and heard a relay click on & was able to start right up. Took the relays out and the blades were really oxidised, quick tickle with some wet n dry and wd40 & been fine for last few years.
andy_coops
  172, VRS, Clio 5
Thanks - great info and I’ll definitely add to my to do list šŸ‘
andy_coops
  172, VRS, Clio 5
Skirts off today. Good news is that the sills appear solid and rot free. Kinda knew that from looking at them when the car was last in the air. Not so great was trying to straighten the front jacking points as they were crushed almost flat. Driver’s side hasn’t come out too badly but passenger side fought me. Rust treatment applied to the worst bits, lick of silver Hammerite to the bits that weren’t rusty and skirts will be put back on with rivnuts.
andy_coops
  172, VRS, Clio 5
Started on a few winter projects.
Firstly the front calipers. Mine are Hammerite’d and look OK but I bagged a set from here, had them acid washed and vapour blasted. Picked them up today, chucked them in the oven for a few minutes then 2 coats of VHT silver. Makeshift paint booth was even rubber stamped by the boss šŸ‘
I’ve ordered a rebuild kit and will be upgrading disc and pad and adding stainless bleed nipples and hoses before refitting.
I’ve also painted my fatty induction pipe satin black. It was looking a bit sorry for itself and I hate polishing metal so took the lazy route. Etch primed and 3 coats of paint.
Nice work.
I’ve recently purchased an electroplating setup so I can do the silver zinc plating passivate properly. And the gold passivate colour you get on other cars.
It’s something I used to send away for a service when restoring minis but always wanted to be able to do it myself.
Simon1975
  Clio 182 Cup/Meg R26
Ignore the sorry engine bay. I bought the jmrs pipe in black think it tidied up the bay nicely
frayz
I hope you have better luck with it Andy, but i found VHT silver just let the calipers rust through in no time. It looks beautiful when applied but is porous and just lets moisture in to the freshly blasted calipers and they rust in a couple of weeks.
andy_coops
  172, VRS, Clio 5
Ideally you want an enamel paint for the calipers,even if just Hammerite.
Foliatec caliper paint kits are good,with a good choice of colours to pick from.
Cheers bud - I haven’t fitted yet but will bear that in mind. I have silver Hammerite šŸ‘
I didn’t know that sir - thanks. As above, not refitted yet so hopefully I can rescue with a couple of coats of Hammerite!
andy_coops
  172, VRS, Clio 5
So with bugger all to do in the way of driving it, started on a mild tidy up of the engine bay. ECU cover painted, repair bracket fitted, inlet manifold, fuel rail and can cover painted.
I’ve also started repainting the spare calipers in Hammerite per @frayz suggestion - thinned it down to give a half decent finish.
The more I do the more needs doing šŸ¤¦ā€ā™€ļø
andy_coops
  172, VRS, Clio 5
Headed to K-Tec yesterday for the car to be assessed and valued for my insurer.
Had a nose around some of the cars they had including a 172 Cup which I’d love to have a play with 😳
Assessment is that it needs a refresh underneath which I knew already - waiting on their valuation.
Great drive home across the southern edge of Salisbury Plain - just nice to be out for a drive. Not much traffic and some great roads to myself.
andy_coops
  172, VRS, Clio 5
What do they mean by refresh underneath?.new bushes etc? @andy_coops
Polite way of telling me that it’s a bit s**t šŸ˜‚ to be fair the chassis and bay aren’t as good as the rest of the car.
- Beam has a lot of surface grot
- Slight play in OS lower arm
- Oil leaks from sump gasket and gear selector
- Cup spoiler stop light doesn’t work
I have a spare beam awaiting refurb, plus hubs and lower arms so it’s all on the to do list. I guess the logical step is to strip the entire underside and do it properly. Perhaps a job for later in the year as I really don’t want her off the road right now!
Horatio McAllister
Bon Jovi Officianado
It’s a winter job isn’t it! A s**t one at that, breaking down in to stages makes it so much easier to swallow! One wheel race at a time I have just sent my spare beam off for coating today. Once it’s back I can tackle the boot floor area and then I’m just about done!
andy_coops
  172, VRS, Clio 5
KTec valuation came through - £4,000. Happy with that and agreed value now locked in.
KTec carbon splitter fitted today - really happy with that. Next job is to start refurbishing the various bits I’ve got sitting in the garage.
andy_coops
  172, VRS, Clio 5
Looks amazing. I love the splitter. That is a fairly reserved valuation in my opinion.
Thanks chap. I guess the difficulty is that under the obsessive polishing, it’s an iceberg 172 with 125k on the clock. I’d just about be able to recreate it for Ā£4k if the worst happened and once the chassis and engine bay are done I’ll get it revalued.
  RS 172
They're going up in price now, that's for sure. i think you'd struggle to get it back to that standard for 4k, but i might be wrong. But i guess you get the brunt of it bag.
Carbon splitter is sick! on the list hehe
andy_coops
  172, VRS, Clio 5
Old manky exhaust be gone. Ktec on and happy. Picked this up from @Mbeau at the weekend and had it fitted today. Ended up going for a stealth tailpipe - wasn’t worried about chopping the bumper but couldn’t be doing with a 3ā€ tailpipe sticking out. Bit of fiddling to get it fitting just right and it sounds exactly how I wanted - quieter than the old system at anything other than giving it the how’s your mother. Spot on.
avstar1
  172 cup
Looking good, how's the noise levels at motorway speeds? Any drone? I'm looking at going the other way and getting a straight through the bumper...
andy_coops
  172, VRS, Clio 5
Not done any motorway driving yet but at lower speeds where it was noisy before it isn’t as bad. Not scientific but it’s a lot better.
