Assetto Corsa EVO
Darren S
A chunky 39GB patch is out....
Version 0.1.4. is now live. This includes:
AUDIO:
- reworked music system to result in better reliability and improved fading
- new music for menu, gameplay and ending sessions
- fixed potential issue when audio device is lost
- tweaked Mount Panorama audio reverb zones
- tuned audio slip ratio logic and feedback
- fixed BMW M4 CSL backfire audio playing in idle
- fixed Lotus Emira compressor sound
- fixed Chevrolet Camaro ZL1 compressor sound
CONTROLS/UI:
- localization updates
- fixed responsiveness issue in Manage Preset UI
- fixed mirrors toggling in multi-mirror (with right mirror disabled by default)
- Showroom: fixed car instrumentation inconsistencies via the car controls widget
- Showroom: fixed missing lights on showroom scene change
- Showroom: fixed incomplete dash display render
- implemented function to listen to concurrent devices: if multiple devices are responsible for the same input
One device can be active, the other device will sleep until they are moved by a margin, replacing the active one
- fixed controller steering assist affecting direct input devices when both devices were connected
- mouse cursor now disappears after a few seconds of inactivity
- changed default FOV of driving cameras (default button now resets to 55)
- fixed overlap between game version and online status in localization
- enabled axis visualization in the controls page
- added 0.2s repeated function for L/R/U/D in controllers
- fixed inconsistency behaviour when making quick turning inputs with a controller
- fixed an issue with garage cars visibility with Italian localization
- increased mirror yaw limits
- fixed an issue with double startup scene loading
RENDERING:
- fixed black screen at Imola and other tracks in triple screen
- disabled TV camera movements in VR
- reduced VRAM usage
- fixed VR and triple screen missing undercar shadows, artefacts on probes, veil flicker etc.
- fixed VR flickering on the sky box
- optimized VR GPU performance
- optimized triple screen GPU performance
- improved car reflections to be more cubemap resolution independent (notably medium setting has an improved quality)
- fixed an issue on resource indexing (fixes some of the minor AMD-specific glitches)
GRAPHICS:
- fixed missing mesh skinning from the Alfa Romeo Junior front springs
- fixed minor visual issues on the Alfa Romeo Giulia GTAm
- fixed Hyundai i30 N LOD issues with lights
- fixed an issue with the AMG GT2 lights colour inherit
- fixed a missing default rim customization definition of a Toyota GR86 configuration
PHYSICS:
- fixed BMW M4 CSL ride height limits
- fixed BMW M4 CSL launch control
- raised minimum pressure in setup limits
- adjusted minimum tyre pressure limits
Updates to server infrastructure to enable online mode for all will be arriving soon.
Thank you for participating in the Early Access Program.
Darren S
Had another bit of solo practice on Laguna Seca at dinner...
  • Mazda MX5 - love it. Rev happy, chuckable, good brakes - nice all rounder.
  • Escort Cosworth - not bad - wallows like you would expect an older (and non-track car) to behave. Had fun keeping the boost on boil. Got it to four-wheel drift on a couple of corners.
  • Alpine EV thing - waft mobile. Felt easy to overwhelm the fronts. Got bored after a handful of laps.
  • BMW M2 Racing - felt good - easily above my current level of ability and therefore poor times. Nice and controllable for the most part.
Working my way through the others as and when. Still love the S2000 and its screaming, non-torque delivery - planting the throttle out of most corners in the dry without any concern that the arse-end wants to slip out.
For those interested, AC Evo is currently £18.49 on cdkeys too. A bit cheaper than Steam. 👇
mace¬
  Clio
@Darren S give me a lap time in the MX5 on Laguna Seca to see how far off I am please.
Anything more realistic than Forza I can't do very well at all and I'm not great at Forza either.
Darren S
Will do. Most likely to be the weekend now, unless I sneak in a few laps with the MX5 later this evening.
I suspect that @andybond would throw down the gauntlet and set the leading time!
I'll make zero changes to the car either (not that you can do much at the minute!) - but at least the cars will be consistent between us all.
andybond
Ill have a go at the weekend. Someone start us off!
Darren S
Would love it if you could pick your viewing preference and select that it applied to all cars. I play with the drivers hands or wheel, usually a couple of degrees raised up and one or two forward. Bit of a pain having to do that with every new car you drive.
I had the settings below for the assists.
andybond
Went on earlier, but didn't clock the times! :rolleyes:
Lost it a couple of times on that double left-hander after the Corkscrew. Back-end being so light and turning at the same time.
I am not fast at all in the corkscrew. Either come in far too hot doing mad corrections or too slow and feel like I could get out and walk faster.
Darren S
Managed to get into the 1.43s with a quick 10-lap race.
Span out early on when I overcooked a corner, but started making my was through the pack once more. Did OK until I got tapped out at the Corkscrew by an AI driver - shithouse! :p
andybond
Cracking time that, Andy.
Which bits to you find the most difficult?
I think I can find some time in the corkscrew.
Also if I get the exit from Rainey curve wrong it ends up in a poor lap
I am not 100% confident that I am fast in turn 11 which leads onto the start / finish straight. 3rd doesnt feel right and 2nd too high in the revs.
Darren S
I think for me - the Andretti Hairpin at the end of the main straight is difficult in order not to out-brake yourself. Then there's the question of a low 3rd gear or high 2nd going through it.
I know I've got potential to make up time immediately after the corkscrew and totally agree - the Rainey Curve is another one of those where your gear selection feels difficult to pick. 3rd seems too slow and in 4th, you're tip-toeing the car like crazy and trying to stop it from running wide.
Darren S
Dipped into the 1.42's at dinner.
The 'revelation' that I had and will work on, is using both the brake and accelerator on the section after the Corkscrew. It seems a little counter-intuitive to load up the front even more and make the rear even lighter, but I presume the covering of the brake helps to pull the rear down a little bit and not to make it as lairy through that section?
mace¬
  Clio
Logged on tonight to get an mx5 lap time but 90 minutes or so later I was doing licenses and never got round to a lap in the mx5.
Bit buggy and I can’t drive but getting the hang of it, not got any 3 stars yet but within a tenth on all the first lot. I’m just crap at it I think 🤣
Darren S
Yeah - still bugs aplenty. I saw a few last night when doing some of the academy licences stuff.
  • Got stuck in a loop once, when I tried to return to the main menu.
  • I had a data error message appear at the end of most runs, but I could at least retry without fuss.
  • The Escort Cosworth had a weird engine noise when hitting the limiter - it almost went silent.
Still a load of fun though. I didn't find getting two stars for the majority of them too taxing, though similar to Gran Turismo and the like - getting all three is pretty tricky. Just started the Supercar class ones with the Lotus Evora (?) and the drool-worthy Alfa FourCheese GTAm.
mace¬
  Clio
lblconnection something or other, seem to record your time but not tell you what you did or what you got? A restart sorted that out for me.
Also got the Cossie sound thing at max revs off the line.
I also missed the end gate at one point and it just let me carry on doing laps lol.
Darren S
Clearly a lot to be ironed out yet - but I do like the constant trickle of updates coming through. I can't even begin to imagine the complexity and levels of coding required to get something like this running well. It's not exactly like you can download a full audio catalogue for the rev-range of a Cosworth, for example.
