Is it any good? In a tin with a black sticker. Seen some vids of it being applied and looks like a foam which you just simply spray on then wipe off with a microfibre cloth?
I wasn't that impressed with ot tbh, didn't do a great job of sealing or stopping surface spots not able to just wash off, but then I guess it's easy enough to apply on a regular basis.
I got better, longer lasting results from using Colli's 476 wax
if you can apply it and wash them reguarly then it might be ok. I'll be trying poorboys wheel sealant next to see if it looks better than the Colli's, especially as it's supposed to be better with the heat
EGP wont be able to withstand the heat. You'd be better to get the Poorboys or the 476s. I personally am using FK1000p Which is a much larger tin than both of the previous for just a tad more. Use it on the body work as well. Cracking stuff.
