aux. and cam price?
Car  182 and cherokee 4.0
how much am i looking at to get the whole lot done at once? aux. belt, tensioners, pulleys and cam belt? also how can i get this done without going through renault?
oh dear!!! canny expensive still! i'm sure renault were talking around a grand or so
On a 1#2 the recommend times are 72K miles or 5 years old. Many would recommend 60K or 4 years on here though.
It’s a big job and a costly job
From an independent garage expect to pay around £450 -650 (172 cups a bit cheaper)
From a Renault dealership expect to pay £600- 1000.
Many chose to have the water pump replaced also as if the pump fails the whole belts job needs to be done again.
Getting mine done for £430 at Renault, no doubt they will find a way to screw more money out of me
got all mine done including oil change and filter for 280 look about fook paying anythin near 500 ,
Where was this mate!?
just a local garage near me i know the lad from school but that was the goin price not a knocked down one:approve: , it makes me sick how much people can charge for work on cars nearly a 100 pound a hour lol and peeps pay it :eek:
Do the alternator pulley while your there. If it fails then the spring can penetrate the belts and mess everything up. IF you get the alternator kit from renault (pulley and belt) it works out about 30 or 50 quid cheaper than buying just the pulley alone! (cant remeber which, but i remember being in shock at how stupid renault were) I was really glad i did mine. It was wrecked when i took it off. The cam belt on the 172 was a bit of an arse. I got my belt from ktec and all in all i was 450 fitted with an mot and new disks and pads but thats mates rates and helping :)
cheers. i thought the tensioners and pulleys were for the aux. belt not the cam belt? are the two links above all i need to buy then? thanks again
if you want the aux belt pulley you need to call renault- cheaper in a kit form not separate.
mate get what you want, but put it this way:
why go to all the effort to change the tensioners (cause the moneys in the labour) and then put an old knackered belt back on that costs 20 odd quid to replace just for it to slip or snap 100 miles down the road. If you dont change the belt your mad. It kind of defeats the purpose of a "cambelt" change. The belts more likley to snap or slip over the pulleys etc failing.
You may as well do as many things as you can with the front end off.
as said before in the other threads youve got about the cambelt kits, its important to do the aux belt pulley. i had a good look at mine and it was goosed. It can cause the belt to foul into the cam belt and make that fail too!
K tech dont seem to do the aux belt kit. call renault and find out how much their kit is. im sure its actually really well priced for once but the cam belt kit from k tech is about the cheapest ive seen. So you need both belts and all pulleys and tensioners. A good garage will make sure youve not forgotten anything.
go to the team valley beside retail world (at the back of halfords) theres a small garage he charged me £400 for cambelt and aux belt
thanks for all the help like. a haven't got a clue about any of this as you can probably tell ha.
how much would it be for a water pump and alternator kit, in terms of parts and labour?
ask a garage- we can only give you an idea. Ive never done a w pump on any car. look up some companies for the part seperate and then call round some garages you know. The cheapest isnt always the best.:)
dont mean to sound like a pr!ck but if you can afford a 182 in the first place surely you can afford to take it to a specialist and pay £450 to have it done properly???? i have just started an apprentacship and can afford it and iam on minimum wage:dapprove:
bare in mind a new water pump too. Just had my belts done at birchdown and mine was leaking. New one on now
not when i have had the car three years, have just come back from a ban and am paying £2,900 insurance. cheers!
