maybe its the windscreen wash motor.
well not the motor, but the valve that switches between front and rear spray.
to spray the back window the motor runs the opposite way to the front washer jets. a bit of rubber in a plastic tube slides accross and blocks off the tube to the front jets and exposes a second hole that sends water to the back jet.
over time the rubbber swells up and the valve no-longer works... so the back window wont gert sprayed.
you cant buy just a new valve, need to buy the whole motor. dont forget to get the washer that seals the motor to the windscreen wash bottle in-case yiou loose the one thats there already. (cos i did and the motor wouldnt fit back in place!)
hope this helps
