Battery choice help
  Renault Clio 1.5Dci
Hi all.
I am in need of a new battery for my 54plate 1.5DCi clio but I have no idea what type I need as they all have different amphour and cca, the battery in the car is of no help as who ever had it before seemed to have taken all the stickers off of it any advice would be appreciated or links to websites that sort of stuff.
Thanks,
Yivo
chris blue
  172 Ph1 2001
My advice would always be to go for a slightly bigger output than the one that is correct spec
Nice to have a powerful battery. usually only 4 or 5 pounds more
  Renault Clio 1.5Dci
Thanks guy. So something like this should do the job? http://www.eurocarparts.com/ecp/c/Renault_Clio_1.5_2004/p/car-parts/car-electrics-and-car-
lighting/electrical/car-battery/?444770757&am
p;1&4bb54698ed38769da6dff9641ec1b5d91b5c0
dcf&000020
Is there anything bad that could happen by putting a battery with a higher amp hour and cca on the car?
chris blue
  172 Ph1 2001
The main problem you will have will be fitting any bigger battery into the space provided. Don't think there is any issue with the alternator charging it up, unless its way over sized
The way I look at it, they recommended a certain boiler for my house, then I asked it to be upgraded to the next size. Cold crank ams output is the main one to watc
and make sure the terminals (Round or flat) are the same as you have
