mine has been mounted between the seat rails under the passenger seat.
Have you got any pics mate?
the car wasnt a daily runner anyhow, it only came out for trackdays.
the kill swicth suitably isolated the battery from any slow drains so it was fine, the most id ever left the car was aprox 3-4 weeks and once arming the kill switch again, the car started first time with plenty of power to take on the task, but for peace of mind i did eventually have a slow trickle charger that was solar powered just conencted to the battery to maintain it and keep it toped up.
what battery have you gone for?
both routes will work well, ive relocated a standard battery in the boot of an old Focus RS, i didnt have any problems with it.
depends if you are just aiming to relocate it or after as much weight loss as possible.
i have the Odyssey on mine, im just unsure if to sell it or keep it to one side ready for the R27 over winter.
you know there is a reason why everything is fused on the +ve and everything is switched on the +ve aswell
i wouldn't like to see what happens if you disconnect the -ve with the engine running
you wouldn't but it can be done quite easily with your setup
why would you fit a kill switch on the -ve !?
