Beards 172 daily project!
Hi,
can someone help? Which Kind of shifter is this. Which modifications have to be done for mounting. Is there a Special Topic for These?
Looks good! @The Beardo Was the shifter easy to fit? Ive got one waiting to go on.
Was really easy to fit, just undo the cat from downpipe, remove the 4x 30 torn that hold the heat shield, undo the 13mm bolt at the end of the linkage, undo the 4x 13mm nuts and the whole shifter will drop down. Took 20mins to do and that's doing it on axle stands.
Hi,
It's a Renault scenic gear shifter, with a race style knob on it. The only mod I've done is bend the shaft a bit more to help clear the dashboard when going into 3rd. Lots of threads about the shifter
Nice work. When you did your EPAS conversion, which inner tie rods did you use for the DCI rack ?
Also, what alternator bracket setup is that ?
I used dci inner ones and 172 outlets if I remember rightly. As for the alternator set up, I used a cup alternator and Volvo 1.7 ( 340/440) brackets. You can also use and still available to buy them from Renault ( Renault 5 1.7, clio 1.7 rsi)
