Whats best place to get brembo hc discs n ferodo ds2500 pads from? Also i've just read there are two types of pads, one is bigger n may need a bit of modification to caliper. Is this right?
I can help out with those brake parts, and I only supply the larger pads of the two available from Ferodo Racing in which ever pad compound DS2500, DS3000, DS1.11 etc
They do need a little bit of filing , but you get more pad surface area and are slightly thicker so more pad for your money
