Best way to listen to music in your car.....
Car  Clio Dynamique 1.2
My head unit only supports.. AUX CD's USB
M aux leads always brake when i use them.
does any one else know any other good ways to listen to your own music.
plus i have a iphone 4 so any apps or anything which could help i dunoo
can someone help?
ye my aux cables always brake too :/ have you tried the usb? works well, if not you could upgrade to a bluetooth headunit and stream from your iphone
bluetooth headunit. i had a sony one in my old car and it was brilliant it will play music from your phone and you can answer and make calls through it to come through the speakers worked a treat for me never had any problems sound was clear as hell too!
Usb for me. I bought a usb stick from argos 8gb and it only sticks out by 5mm its tiny so it doesnt really stick out.
Pair the iphone (under settings), then play music like you would normally on the iphone.
The headunit should be able to at least skip forward and back a track, and play pause, once a playlist is selected.
