Black Gold K-TEC Turbo'd Clio 182 (292BHP@8PSi)
Trader Rating - 100%
3   0   0
  Evo 5 RS
Hasn't that engine been opened up more times than granny's gash? Or am I thinking of another legohead
Pretty nice spec though, I'd say it's worth 6,500 - 7 all day long as long as it's fit. Although as far as so-and-so's engine building goes from what I've seen so far, it probably rattles it's tits off.
19   0   0
  340i
That engine has been apart more times than I can remember!
harnesses attached to the rear strut brace, safe.
apart from that it does look a smart motor ;)
3   0   0
  None :(
Glad you mentioned the harnesses!!
You should tell your friend to read my project thread, he should fix those harnesses and it doesn't cost hardly anything to do!
16   0   0
your harness's are still in the wrong place james , you will break your back if you have a big accident due to them being screwed down so low !!
3   0   0
  None :(
Yeah that is true, which is why i'm telling the miss's i need a cage!!! :rasp:
I was advised what you have just said, but at least it is safer than before.
