Clio III - 1.5dci
I defer to the wisdom of the forums. Just about ready to blow my brains out.
So, I recently got my hands on a Renault Clio III 1.5dci 68 - my friend overfilled the oil by half a litre and all hell broke loose. He got in a mood with it and sold it to me.
Initial symptoms:
* P0670/$07E8 - Glow Plug Control Module Control Circuit/Open (code pulled on a Foxwell OBDII scanner)
* Blue/White smoke out of tailpipe (smells like oil burning)
Initial repairs:
* Test all glow plugs (resistance was CRAP on all 4 of them)
* Replaced all 4 glow plugs
* Complete oil change with 5w40 magnetic, as he was using Halfords brand and I thought it worth a shot.
All codes disappeared at this point, well, none could be picked up by my eBay £12 OBDII scanner ? - HOWEVER, the following issues occurred and/or remained:
* Electronic fault warning light on (through ignition, turnover, and driving)
* Dashboard warning light on (the service spanner - through ignition, turnover, and driving)
* Blue tint smoke remains a constant issue and is particularly bad under load but still there when idling
* Difficult to start and rough idle until it warms up a little (1-2mins at most) then idle levels out (this was an issue from the start)
* Once warm, foot on accelerator to 1500/2000rpm seems to 'bounce' around when held steady, but 2000rmp+ no bouncing up and down ?♂️
* OH! Also, at this point, I found a massive amount of positive pressure (I think it's called 'blowby?') coming from the oil filler cap.
I then tried the following to no avail:
* Clean MAF sensor with MAF cleaner spray
* Remove EGR valve and pipe and decarbonate (they both look brand new, GO OVEN CLEANER ??)
But, neither of these things fixed it.
I have noticed that there appear to be two or three spots under the very front portion of the car where oil is slowly leaking on to the road, and I mean slowwwwly... Absolutely no idea where that is coming from... I have taken a look at the cylinder head and am sure it's not a head gasket issue. Also, the coolant looks clear...ish? (It's due a change). I'm starting to think piston rings? The weird thing is that the car was running perfectly until he overfilled the oil!? Can anyone think of any other simple issues it could be before I give in and go and get a leak down test done?
Much love to the community ?,
Alz
Initial symptoms:
Initial repairs:
Alz
