Bolt for removing rear seats rounded off
On the middle bit that holds the back of the rear seats in, the torx screw has basically rounded off, the outer bit is circular so no idea how to remove it. Any suggestions?
Cry.
Either, drill it out, hammer and chisel, or smash a socket over it, if it's soft, although imagine it's too hard for that, so hammer and chisel.
  Qashcow
It's reinforced steel I'm told so a drill will do feck all unfortunately!
whats reinforced steel? if its a harder form of steel, so long as u drill slowly, not flat out like most people think it will give. or use a hard plate drill, although they tend to shatter easier
Struggler
  Ph1 track 172
curved mole grips?? monkey wrench?? rounded bolt removal tool??
hammer a socket on??
is the bolt completely in?? or is it half out??
  106 GTI
In ref to what bomber has said use oil as a lubricant/coolant. works a treat
Hi bomber x
  3 Series touring
Once you get some flat sides on it, chuck WD40 on it, then undo as much as possible...then more WD40 then screw it back in , then undo as much as poss....etc
this is what i had to do to get the oil right down and get that fecking bolt out!
DMS
  A thirsty 172
I've now got this same problem. The f**king thing has rounded off!
Nothing I've tried has worked so far, so tomorrow I'm going to file / grind a couple of flat sides onto it and get the adjustable spanner on it. If that doesn't work, I need someone with a spot welder :mad:
  ph1 track weapon
i ust hacked the head off it and have left the stump! covered with a little duck tape!
DMS
  A thirsty 172
can you get to the thread underneath the car, or is the beam/tank/etc in the way?
No idea. I'd like to know though - might give me a couple more options.
Not a bad idea actually. If I could hack the head off it the bracket would lift over the top I bet.
I suppose I could then drill the thread out whenever I could be bothered, or get some mole grips on it underneath the car and take it out the wrong way if that's possible?
if you can get at enough of the thread from underneath, try wire brush/wd, and then wind it up by locking a couple of nuts onto the thread
Daniel
  Whichever has fuel
Seriously, you're wasted working for royal mail!!
  Golf GTD Mk7
socket, hammer , job done
Won't work on that bolt. They are a b*****d to get out at the best of times. Copper grease everytime is the way forward. Get the angle grinder on it, just try not to set fire to the seats :(
  recaro'd 172 rep
i had this problem, the bolt is seriuosly hard and tight. in the ned i had to weld a nut ontop so i could get a proper socket on it.
DMS
  A thirsty 172
Sorted it! This is how I did it...
Yesterday I had managed to get the bolt out a good 7 or 8 turns before it rounded off, so some of the thread was exposed. I decided to spray some WD40 onto the thread and around the hole then tighten it back up a couple of turns - my thinking was that it'd make it easier to get it out when I managed to find a way to do it.
I went out today and brought myself a set of good quality drill bits. I first used a 4mm drill bit to drill down inside the bolt hole. Then I used a 6mm drill bit to drill into the existing hole (my cordless drill is a bit puny).
The result... I had more or less turned a T40 hole into a similarly sized hex bit hole.
I hammered the right sized hex bit into this hole, attached my ratchet and associated extensions and proceeded to undo it with very little difficulty.
Ironically, I can tighten and untighten the bolt very easily now - all the way in and all the way out again.
Pic, because I'm proud of myself and my newfound mechanical ability:
  197
self grip pliers does the trick along with a load of DW40! will take longer than it would with an angle grinder though
