Bolt spacing on 1.2
VIICarCare
  255, 230, 172, R26
Hi guys, well the plan was to buy some VMax Coilovers for the 1.2 but im just in the middle of buying & selling houses atm so money is tight.
My question is, is it possible to change the bits that are 52m to 58m for the cheaper coilovers? Or do what matie did with his beutiful dci rep & change the entire subframe at the front? (sorry, can't remember your name! :eek:) The rears wouldn't need touching would they?
I have thought of selling the 1.2 & buying a dynamique just so i have the standard 58m bolt spacing! :dapprove:
Advise please guys! All I need is her sitting lower then I'll be happy! :D
  Discounted 1*2 parts
If you are converting to 58mm spacing (i.e from a sport) then you'll need new hubs, carriers, brakes etc. This means you'll probably also need the bottom arms, driveshafts etc.
  chumpmobile
there is a thread on here about that iirc. he spent just as much swapping parts +rokkors (he did all the fitting himself) than he would of spent buying v maxxs in the first place
VIICarCare
  255, 230, 172, R26
Thanks for that guys. Dunno how i managed to miss that thread!
I dont want to convert to 172 bits, just standard if it can be done tbh.
So, can i get those bits from a clio dynamique? And how come the discs & calipers needed replacing? Didn't say in that thread.
If I can find the parts cheaps enough then why not?
Sorry, i just want her lower!
ta :)
VIICarCare
  255, 230, 172, R26
really? what hubs do i need? (lol, which model clio?)
sorry im new to this!
  Stripped yozza'd cup
The 1.2 16v has 58mm hub spacing, pretty sure the 1.4 does too. Don't you need to change the drive shafts as well Fred?
  Lionel Richie
hang on, you have 52 at the moment and you want 58? correct?
then whilst your at it upgrade to the 259mm discs, calipers and hubs, bolt striaght on - done
VIICarCare
  255, 230, 172, R26
Yep, its 52 atm. Do i really need to upgrade the discs & callipers as mine are newish.
The hubs i found are from a 16v clio. Will they fit? Sorry for all the Questions, I really apreciate your help peeps :)
VIICarCare
  255, 230, 172, R26
guys? lol
so i just need the front hubs from a 16v clio? Nothing needed on the rears?
  e92 330i
Buy it, try it, if it doesn't work put it down to experience. Sorry that's as much help as I can be :)
  Ph1 track 172
if you're refering to my thread, i spent quite a bit less,
and ended up with brand new discs, higher spec brake, and a freshly blead system!
but yes, whipping just the hubs off a 1.4 16v should be enough.
But make sure you measure, im certain ive read on here about 16v non-sports having 52mm hubs and visa versa
but be very careful with the ball joints when removing and refitting if you plan to keep the same ones!!
and yes, 100% the rears will be perfectly fine to take any mk2 suspension setup!
VIICarCare
  255, 230, 172, R26
lol, cheers for your help mate. Im going to buy the hubs, then the rokkor coilovers when i get some cash! My brother is a very good mechanic :)
