I guess it depends if you were giving it hell in summer or pottering around in icy cool temps haha!
EDIT just seen you said december, so it's obviously been f*cking freezing ever since then.
That golf rad won’t cut it @Martin.
If you were to have a custom made rad in the same dimensions with a wrc spec core, it’ll work well enough. You’d need to duct air through it though like I did on mine. Gets maximum efficiency.
You've just confirmed what I secretely knew deep inside haha, but was hoping there was a glimmer of hope.
Having one made with a WRC core sounds eye wateringly expensive.
Have been looking at the Direnza equivalent for the Clio fittment. The core size is 1.8 times the standard rad core. And it looks like it's 1.5 times the size of the VW rad I've got currently. Which is a considerable amount.
Well my 230 n/a motor was kept cool by the same rad that you’ve got, but it was definitely being pushed to cool it when you were making progress. The laminova coolers I had for the engine and gear oil wouldn’t have helped as they add more heat into the system, but it was being pushed.
That's a van used on the road though right
