Braided Line Fittings (Rear Caliper)
Car  Clio 172 / VW Passat
I want to have some braided brake lines make up but I can't work out which fitting I need to connect to the rear caliper. I need them to be a specific length so can't buy one of the off the shelf kits that are available.
Is there a fitting that would do the job or do I need to use some kind of adaptor to convert the thread in the caliper to then use a -3 JIC fitting?
Any help would be appreciated.
You dont connect the rear braided lines to the caliper. You only connect the line on the chassis to the line on the rear axle.
