Brake lights not working
Car  172 Cup
This is on a MK1 172 the lights have worked in the past and now all three of them dont work the fuses isnt blown so i dont know where to go now.
Any Advice
Brake light switch just above the pedal... its either clicked all the way in or you need a new one they are not very much.
I'd say it's the brake pedal switch as Jon says. Failing that though I guess the earth could be loose or similar, do all the other lights work?
The switch is mounted on a bracket up above the brake pedal. When you press the pedal it activates the switch lighting your brake lights.
You will need to look up 'n' under! :)
