Brake Lines + Ball Joints
Does anyone have any idea where I can get these, ideally ASAP.
Need some standard brake lines from a 172 Ph1, new....and Bottom Ball Joints for the wishbones.....Buying a whole new wishbone isnt an option, as powerflex bushes have been fitted....
Need to be both for a 172 Ph1. Eurocarparts dont stock/cant get either, nor can GSF.....anyone have any ideas?
Thanks.
ive read on here people have got them from eurocarparts for 172's, but they say they dont even do the wishbone now....somewhere surely has to sell them........ie if the bushes are replaced in the wishbone like mine have been
renault don't list them seperately, some non gen parts suppliers have them listed but its the same part numbers as all the other non rs ones and they are wrong when they arrive. The ball joints were fine on those arms weren't they? or you just wanting to have new everything to keep it tight?
ive replaced the bearings in the hubs joshy, and polyflex'd the arms, so i was going to get new (considering id seen people say they were around 8 quid each on here).....but if i cant find any, il use them for now and replace them.......
brake lines are the most needed item to be honest, cant be bothered with stainless yet as im only running std disks/pads
oh and that package came today thanks again :)
foxy..
balljoints, phone euros again and ask for the same thing,, chances are a different monkey on the other end of the phone will find them
if not, i dont know if you have branches at your end,, but i know for a fact motor parts direct sell them.
as for brake lines, make them from copper pipe mate
much easier to fit, just as good (if not better as you can route them better)
and easy to make, just need about 40 quids worth of flaring tool
QH make seperate balljoints so they are avaliable, a local factors can get them easily enough here so you should be able to get some. Brake lines wise i'd imagine goodridge lines are cheaper than standard.
