brake pad change
ross_16v
  172 Cup
got myself a set of red dot brake pads for my valver but when i read through the haynes manual it said you have to replace the guide pin bolts aswell. But if i want a set of these i would have to buy genuine renault pads. Should i just reuse the old bolts?
  172 cup,s2 rs turbo
you could reuse them if you put some thread lock on the threads but some new ones will only be a matter of pence.
ive had mine on and off a few times and as jay172 says suggests just use threadlock, its not a problem, and they aint ever come loose on me
  20VT Clio & 9-5 HOT
are these the 2 huge bolts around the back? if so i need to put some thread lock on mine as well
