Brake Problem 172
Car  Monaco Blue 172
Hi,
I've had an issue with the brakes on my 172 twice now.
The brakes felt like they were on / sticking badly and the car wouldn't roll backwards at all and it took much more effort to pull away. The pedal was also a lot harder. Then I had the stop, ESP and service light come on. Turned the car off and back on again and all was fine?
Does anyone know what this could be or had the same issue - couldn't see anything on the search function.
Re: Brake Problem 172 FF
Had the problem again yesterday. Exactly the same as above. Turned car off and on again and all was ok. I described the problem to my local specialist but not they're not sure either.
Vacuum valve, have a look in guides, I did a little write up about this prob, and the fix
No idea, but there is not such car as a 172 FF, drop the FF
Hows is writing 172 FF easier than just writing 172?
Guides are for members only right?
What is a vacuum valve and is it a major fix costing major money? Thanks for reply, shame others go off topic.
Cough up the £12 quid to join tight arse and you will find out lol
It's not an expensive job don't worry.
