Brake Question
Car  Kawasaki ER6N
So need brakes on the front of the cup and unsure what to do however I am aware I I'll get mixed opinions.
Option 1 brembo max with red/yellowstuff pads around £150
Option 2 ebc discs with red/yellowstuff pads around £160
Or this combo from ktec with the best pads £160 again
http://www.k-tecracing.com/show_product.asp?id=1148&appid=2
Or any other options you would suggest.
Don't really want to spend £100+ on pads alone as have other work to do on the car aswell just after a general upgrade for road and maybe 2 track days a year.
I'm sure I have had it drilled into me that grooved discs are better that's all however hc seem to get good reviews on here.
Everyone uses the HC's and DS2500 setup, I've got the HC's but Mintex M1155 pads, once there warm it's STOPS.
Will go for the hc and 2500 then I think as don't want to do a track day to find the pads die.
Thanks for the help.
Don't forget is your using auto-nation, discount code cliosport11. This will only work once your registered.
Mine came within 24/48 hours. Any long and he will ring you and explain.
That's how I ended up with M1155's, M1144's I ordered was on back order, so give me a free upgrade. Almost twice the price of the original order.
Got ebc bluestuff and brembo hc's on mine. Performed really well on track although im considering upgrading to wilwood 4 pots.
I'm considering yellow stuff or black diamond predators they both have a good write up. It seems ds2500 are abit much for road driving.
