Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
yeah depends, i bought standard for the rear, with bearings and pads for around 100quid.
then got brembo discs and pads from nextdaybrakes.com for the front for 85quid ish
If you have a cup then you do not abs rings do you.They come with them anyway from Renault.Should take you about an hour to change the lot.
Don't go drilled,not needed.
Make sure you have the deflector (sp?) ring behind the bearing when you remove the rear disks. I went to change mine at the weekend and the OS was missing. Ordered some from Renault £14 quid later I have just fitted the lot.
