BRAKES HELP ME PLEASE
MaLicE
Honorary Member
  Lazy v8
right i need some new brakes mine are basicaly just about shot.
ne way its for a 93 l 1.4rt clio.
needs to be good looking and have good performace.
need discs and pads and ne thing else.
can i fit vented discs on ????
can i fit valver calipers on ???
would like big discs but not massivly expensive ok.
MaLicE
you can fit std clio 16V/willy discs and calipers straight on no mods.
You can also fit any varation of the 16V/williams big disc kits and 4 pot kits.
Only problem is that master cylinder size becomes too small.
MaLicE
Honorary Member
  Lazy v8
can u put bigger master cylinders on ?
and with it being to small what does that do ??
and why if i have solid discs cant i fit vented ????
MaLicE
  BMW 320d Sport
Vented are too wide for your caliper I would have thought. Ive still got a set of 16v front brakes for sale, calipers, grooved/drilled discs/ Ferodo DS2000 pads. Theyre promised to someone else but Im still waiting to hear if theyre having them...
MaLicE
Honorary Member
  Lazy v8
nick m8 how much u want for em ???? hows the car going u got your seats yet??
Mat would it be hard to fit the master cylinder??
MaLicE
master cylinder aint an easy jop, space is tight.
problem with a smaller master cylinder is that you cant move as much fluid, and moving the caliper piston becomes a long travel affair.
But you can fit vented discs as long as you use the 16V calipers.....they wont fit the std crap caliper.
MaLicE
Honorary Member
  Lazy v8
so if i fit 16v calipers and some vented discs and new pads will that be better or will i have problems with the master cylinder???
MaLicE
did you ever find out the answer mate? im gonna redo my brakes this week, but if ill need a new master cyl to use valver brakes sensibly ill just get OEM crappy stuff!
can i use grren stuff pads with standard discs or is it not worth it?
