brakes rubbish in wet
I've got a 172 cup. When it's really wet the brakes take ages before they actually feel like they might stop the car any time soon. I guess it's while they heat up and vaporise the water.
I have cheapest pads I could find, so maybe that's a problem but they are fine in the dry.
Anyone else get this problem?
Any pads anyone recommends, for road and occasional track driving?
Mine are the same - absolutely shocking - pads are OEM Renault whatever is fitted as standard. Looking for a drilled od grooves disc upgrade with pads to match.
I've experienced this, usually after cruising on the motorway for a while without touching the brakes. I assume it is because they just get completely soaked and this reduces friction when you first apply the brakes.
Its actually worse with the Ferrodo DS2500s' I have now as they like some heat anyway! They are very good the rest of the time though ;)
