Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I am wanting to get some new discs and pads for my beast and I am wondering what are the best to go for. I am looking to spend around £150, Ive heard Torox G88 discs are good, but im not sure what pads? There have been no performance mods done to the engine if that helps!
Dont bother. ditch the standard calipers and get hold of some clio 16v ones. Just get some standard 16v disks as you dont need to uprate them. they will now be vented and about 30mm bigger that your standard disks anyway then stick some decent pads in there like mintex, and enjoy much better breaking. All of this should be well under 150 as well.
I did the 16v/Williams Brake upgrade - the difference is amazing!
Cost with Brand New Discs, Brand New Pads (Originals) and Calipers.. just under £110.. well worth it.. so so so much better than the standard ones I had..
got some 16v calipers, braided hoses, drilled and grooved discs and performance pads on there way this week so i would like to know how much of a difference!
when brakin from 90+ i might as well stick my head out the window coz the window resistance would proberly slow my down faster!
if standard 16v brake setup is that much of a difference im scared wot these are gonna be like!
just doing the same my self, got some girling calipers, some brembo discs (not drilled or grooved) and some pagid pads, should all be fitted by tomorrow, got some dot 5.5 brake fluid also.
I did what your doing to yours now essex boy made loads of difference. Only thing i found though was that they needed alittle more time to get up to temperature. But they were very very good.
Cheers lads great help! I nearly went into the back of a golf coming home from work tonight so I think I need them soon! Does anyone know where I could get hold of some from and is it possible to put the back 16v or willy discs on aswell, how much trouble is it?
valver/willy brakes on a RT makes an huge difference... have done it on mine but I still have brake fading away....
Im looking for some kind of air-piping cooling like the ones used on the clio cup racing.
Just stick to DOT 4 or at most castrol response Super Dot 4 synthetic brake fluid.
Firstly dot 5.1 will need more regular maintanence as itll absorb water quicker. Youll never reach its boiling point in general use, infact youll never reach it unless you drive at 60 non stop with the brakes on.
I dunno how you can get brake fade, i dont even run fancy pads and discs or fluid on track and ive never had a problem. What possible benefit can you get from 5.5 fluid!
