braking issue
Car  172
before i purchased the car it had the brake fluid change
i have a problem with them, when i press the brake it goes right down, then press it again and its solid
there is fluid coming out the resivour as well.
whould it just need bleeding or maybe servo issue??
cheers
first thing id do is bleed them, is the cap on the resivour?! it shouldnt come out of the resivour atall, check the cap and all pipes are tight and that its not been over filled too.
dont let it go above the max marker.
if its leaking from reservoir area and theres no servo assitance deffinetly need to change the brake master cylinder and servo unit
