Re: My Ph1 172 track sl*g Progress Thread
Proper update time................
A few days ago my Bro came over to help me with a few things. He's much better with a dremel and has a good imagination. Just what we need.
We rescued the centre vents from the bin and with a piece of carbon set about making a housing for the hazard switch to go into. I was going to put in in the panel where the headlamp adjuster normaly lives but I wanted to fill the gap left by the centre vents.
As I now have no space for the radio in the centre of the dash I decided to relocate it to the glove box. I need it to stop me gong insane on long drives.
I got myself one of those housing like they use on old mini's to bolt the radio under the dash. Needed to trim it down to fit in the glovebox.
Cut the back of the glovebox to allow the radio to stick out the back, making the wiring connecion easier and so it fits nice in the space.
Quite neat I think.
All I need to do before setting off is switch it on and put a cd in, the display and steering coloumn controls still work, so its fine when on the move. Makes me look more hardcore coz it looks like Ive binned it.
The wiring looms dont reach this far. the display one and the ariel are fine so its just power and speakers that needed to be extended. To save me having to cut the loom and extend it I got hold of a short iso loom ad extended this to make it all plug and play.
^ that pic is of my first attempt, before id actually measured how far it needed to go. Thay are much sorter now.
While my bro was over he made me some small brackets form some dash off cuts to secure my panel in better.
Now, a few weeks ago when my mate was over and I started to get the new dash in, he made a start on removing the ABS!!
2 Reasons for this. It was nothing but trouble at Curbourgh back in the summer (As Tony will agree) and I need the space where it sits for my new pas pump.
The pump is off.
and I have bought a bias valve to put in the rear line.
No further rogress has been made with this so far, altho I do have everything I need to make up new brake lines etc. Now, after removing the pump, the ABS light has stayed on. Of course. Now I did think about tracing the loom back and maybe putting a resistor in or something like people do with airbags but it would take me ages. So I decided to strip the clocks apart and deal with the lights themselves.
Got down to the board and as some of you will know the Clio doesnt have bulbs in its dash clocks, like normal, but has surface mounted LED's.
So do we de-solder them, NO, Just break the top off it, Lol.
Had to do the ABS light, Serv Light, Stop light AND brake warning light (more on this in a bit) All these lights stay on coz of the abs fault. While I was there I took out the front fog and airbag (even tho it isnt on anyway) warning lights. This works well as it leaves the other lights working. The other idea we had that would be NON permanent woud be to put a very smal bit of tape over the led so it doesnt show on the dash. Might be a good tip for anyone with an airbag light on after bucket/steering wheel fitting and is a girl so wont cut the loom.
After this I set about marking up my switch panel after a tyring a few layouts made from cardboard.
Trial drilled a scrap bit to make sure it wasnt going to look s**t after id drilled it
Started drilling and fitting the switches. I have a brake warning light on the panel to overcome the problem with the one I had to break on the dash clocks.
Having a surface mounted fuse box for a couple of extra circuits I need to run.
trial fitted it all to see how it looks........
Very good I think :approve:
