Camber Bolts
they are not universal. you need to buy ones for a sport. non sport ones have a different size bore for the bolt
Ah ok cheers.
Is there anywhere I can get them from thats cheaper than K-Tec?
Im not sure if thats the case tbh, aren't all clio bolts and hub holes the same??
probably but i would stick with k tec h&R bolts. although expensive they are good talking from experience. ive not tried the eibach ones so cant comment on them
I had the eibac hone on my twingo gt. and had no problem with them. You should go to your local car tuning shop and haggle a bit.
There isnt really anywhere up here mate ^
The eibach camber bolts from K-Tec come to £50 delivered which is ridiculous. Where else can they be had from?
Would the ones linked in the first post fit a MK2 non-sport, as it says only MK1's up to 1998... just wondering if the bolt sizes are the same?
Fred will you let me know too please?
He can beat the k-tec price but only by a couple of £'s and thats for whiteline ones that only adjust 1.5 +/- degrees.
I ended ordering them from K-Tec this morning because I need them asap, but I'm not happy to be paying £50 for 2 bolts! :(
I've got a set of H&R camber correction bolts for a 172Cup that i've never had fitted (didn't bother getting new suspension in the end) that you can have for £35 posted ?
any use to you?
Am I right in thinking I have been sent the wrong camber bolts from K-Tec...?
The one on the top is the one theyve sent and the bottom is the original.
I fitted them not realising and the hub moved about from the strut.
