Camber bolts
Car  Dodgy one
How much are they :eek: Anyone know where i can get a set cheaper than ktec to go with H&Rs for a cup packed 182 and allow me to get -1.5deg camber?
I had been looking over on clio trophy too and they talk of using a 12.9g 12mm bolt which gives 2deg adjustment, Bodge or worth a shot?
Tweeks i think your going to say, found them, I think can anyone confirm the correct part no before i place an order
You will only get around -1.5 deg using these bolts and you need to use spiralock nuts to be able to torque up tight enough.
mine worked fine for around 2k road miles and plenty of track work.
As above, i've got these on my 182 (cup packed) and they give -2.3 n/s/f, -2o/s/f camber. Using the 12.9 ISO bolts (12mm) and Spiralock nuts. Cost me virtually nothing all in. Tracked them twice and they have been spot on.
