Camber, Caster & Toe... What should i get it set at?
Car  Trafic 140dci
Hi all, this is an area i'm pretty thick in tbh. Want to address this at the weekend in my preparation for Nurburgring.
All i need to know is what should i get all these factors set at front and rear for a good track setup. Please note although my car is road legal, it's predominantly a track car so that is all i'm concerned about. I have FK coilovers so camber is fully adjustable on the front :)
Thanks for any help
Lewis
I am running -2° camber and about 3" toe out on the front. Handled pretty well on the 'ring.
Thanks mate, -2° sounds like what i should be going for with camber, is that 3 inch's toe out? Been suggested 3mm by someone else and 20 minutes, don't know how they compare lol.
Sounds a lot of toe out to me. We only run 1mm toe out. But everybody's different.
I appreciate your contribution tbh Tony, at the end of the day your racing a Clio and getting good results, think your opinion is gospel here :) I'm no racing driver and have very little knowledge of setting it up so need to get a good bench mark to start from.
  • Like
Reactions: HSH
I run 2.5 degrees camber on the front, as much castor as possible (using Ast top mounts) and about 15-20 minutes of toe out. Handled like a dream at the 'ring last year and has remained unchanged for this very reason.
I also run less toe in on the rear as well. Keeps things nice lively that way. Makes the rear very twitchy but turn in is excellent.
Thanks for all the replies, i think i'm going to go for -2 degree's camber to make the tyres last a bit longer, and about 20 minutes toe out as this seems to be a good compromise too, and know a few people running that setup so can't be too bad :)
1mm is roughly under 5min, nowhere near 28min(half a degree, you can easily see many mm difference at this angle) !
Agree, its not 28 mins by my calcs. However, nobody has said if it's total toe that is being quoted or single wheel toe.
Easy to calculate and to sum up the figures for 1mm toe are:
1mm toe on a 15" (381mm) wheel = 0.15 degrees (9 mins). So if it was TOTAL toe of 1mm then it would equal 4.5 mins per wheel (as you suggest)
