Cambus/Speed pulse info
  Clio Extreme 1.2 2002
guys,
anyone know if the Clio 2002 needs a cambus adaptor in order to get the speed pulse info? Or weather it can be taken direct from the Speedo? Also if there is anywhere easy to get too that I can get the speed pulse info?
Reason is I need to stick in a Satnav unit for testing and need Speed pulse info in order for it to lock on properly.
Some other makes of cars require a Cambus adaptor that splits the speed pulse info for you as you can not get it off a single line.
Any help guys?
  BMW M135i
The violet wire in the power iso connector is the speed pulse I believe, beyond that I can't help you.
On the 1998 model it's a Purple wire at the back of the instrument cluster, there is a black 10 pin connector. Pin 8 carries the signal. Dunno if it's the same for a 2002 model.
