Can I stop my xenon auto height adjust?
  182 FF
This evening I went to manually adjust the height of my Xenons on my 182 as they're too low, using the Allen key method.
I found that on my passenger side, the height adjust motor is constantly turning and the headlight is moving up and down over and over again moving the light beam very very slightly.
Is there any quick and easy way to disconnect this motor or pull a fuse to stop it constantly turning?
ta
  E46 M3 + Ph1 172
It should be connected to a wishbone via a plastic arm, just pull the arm off? Its like a droplink.
