cant get the cold air feed pipe in properly :(
  clio 182 cup
iv got a pipercross viper iv tried to get the cold air feed hose in properly and i just cant do it, iv placed the trumpet in my grill nnext to where the towing eye goes, removed the air sensor and bracket to make room and fed it up behind my headlight, i just cant get the angle right and cant get it to sit in my grill flush, its just too big. how is this done? thanks
  182
Where did you buy it from? maybe a quick call to them might help, or bite the bullit and have LAD in morcombe fit it for you
  C-VXR, T8 Map 220BHP
i made a small hole each side at the end of the CAF then put cable-ties though the holes and attached it to the grill, keeping it flush.
  clio 182 cup
why who does it in morecambe? i can get it in the grill but because the cold air feed is so thick it wont go back enough so the trumpet wont sit flush thanks
  182
LAD motorsport are renault/pug etc specialist based in morcame. Make wild claims about their tuning that has been rubbished on here but i'm sure they'd sort your CAF no probs for an hr labour
To be honest the cable tie idea seems the way forward IMO
  clio 182 cup
i still need a new piece of pipe anyway :mad: its just a little bit too short, yer the cable tie idea sounds good, does this place in morecambe do remaps?
  182
You could cut a hole through the grill? I'm not the most clued up though to be honest not sure it thats a decent idea...
  clio 182 cup
i have cut a hole in the bottom grill and sat it in the cable tie idea would hol it in place , just need 2 get a longer pipe now, thanks
  Clio 182
HI
I spoke with Pipercross themselves over the poor quaility fit of this product. When they designed the kit they removed one of the fog lamps to run the CAF to the lower grill. I will be honest I send mine back after 2 days and got a refund via my credit card company because I was so dissapointed. I suppose it depends if you are after noise or an expected performance gain? Neither were impressive for me when I tested the kit.
Rich :)
  Clio 182
182_racing-blue
You are correct I am sure they are, however when I buy a car with fog lamps i expect to be able to use them when required- yes I agree that isnt very often but for me it was the principle, for anyone running a track car they would be advantagous if fittted/setup correctly.
Rich :)
1
182-racing-blue
182_racing-blue
Rich :)
Like when you go to McDonalds or down to Southend?:rasp:
