car tried to die on me 172
Car  renault 172
right this morning i drive 1 mile to motorway and join all off a sudden it starts to die dropped a gear an d carried on with a minute it did it again then floored it and it was fine
your thoughts please no managment lights but has a dirty kan filter on it could this be the cause maf not reading signal should i clean it newbie be gentle
When you drop the clutch the engine is trying to stall??
try typing clearly and more people will help you (advice not a dig)
all i did was go up the slip road joined the carrigeway and it sort off like misfired then went back to normal within one minute it did it again then drove 20 miles too work im in rochdale near manchester regards
so are you still having the problem?
is it not stalling?
i would check you have the correct plugs in really
90% they are cheap s**t bosch ones in most rs clios on the road
is it not stalling?
thanks guys appreciated was serviced by renault last year cambelt was done and 45k service so i presume they were done
