Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
changed box
started up was fine
then just died
then start up again then died again.
then just wont start.
theres no spark.
so it turns over now.
then just stops turning over and cuts.
As in you made sure the plug was pushed fully home as if it wasn't the initial start up could of vibrated it enough to break the connection which would result in the lack of spark
Had similar problems when I fitted a C20XE lump into an Nova, spent ages trying to fix it and it turned out the earthing strap bolt wasn't done up properly
Clio 2's go crazy when the battery has gone flat. The ECU seems to loose the imob code. The imob light stays solid and the starter cranks and then stops itself after 1 second.
If you get in the car, close the door, turn the ignition on for 30 secs, then off, lock and unlock the doors and start it. Should work
