Changing window motor Clio MK3
Car  Clio Mk3 1.2 Turbo
I have removed the 3 screws holding the runner frame to the door and moved it out of place... But it still seems to be stuck at the top a little? It will move side to side but not down or up. Does anyone have any experience removing these before? I'm just trying to get access to the window motor so I can replace it with a working one :dapprove:
This picture is with the bolts in, there are 3 bolts that I have removed but the top won't move much. I didn't know the glass is clipped in? I already have the whole part here ( Another that I bought ) but thought the glass sits inbetween the two plastic bits and not clipped in?
Check with your dealer but renault mite pay it will also need a connector as well. And a door membrane.
I asked at Renault about my window problem a week ago and they wanted £50 to have a look at it.. I know this is a common problem with the MK3, they didn't say anything about paying part of it. so I looked at it instead and I'm sure the motor has gone. Will ask them tomorrow if they can put in the window motor I've got.
Definitely needs a new door membrane it was all duct taped when I pulled the frame off. It will also need a connector???
