Clear instructions in copper greasing brakes
Car  Suzuki Ignis Sport
My brakes are still squeeling after changing the pads.
Can someone give me a guide to copper greasing my brakes. Thank you.
undo the 13mm bolt on the caliper (lower of the 2) lift up caliper, pull out pads whack on the grease (don't go mad) little bit on the ends
job done
Just take it to a garage then, tbh brakes aren't the thing to be f**king about with if you dont' know what you are doing
As lunner said, can be dangerous if you dont know what your doing. Once you've done them a couple of times it's a piece of piss though
Popping over to the garage who did my brake pads after work.
What should i ask them to do??
