Hazza Car Suzuki Ignis Sport Oct 8, 2007 #1 My brakes are still squeeling after changing the pads. Can someone give me a guide to copper greasing my brakes. Thank you.
L Lunner Oct 8, 2007 #2 A guide???? If you need a guide for that maybe you should be letting a garage change them for you
Shindig Car Less Oct 8, 2007 #3 take it to a garage and then watch what they do , so you know for next time.
Hazza Car Suzuki Ignis Sport Oct 8, 2007 #4 they tend to get u to sit in the waiting room for safety purposes tho
F Fred@BTM Car Lionel Richie Oct 8, 2007 #5 undo the 13mm bolt on the caliper (lower of the 2) lift up caliper, pull out pads whack on the grease (don't go mad) little bit on the ends job done
geesus69 Car F4R'd ITB'd '92 cup racer Oct 8, 2007 #7 Laingo said: And that's on the BACK of the pads btw lol. Click to expand... :lolup: ive seen someone grease the face of the pad before lmao altho he was very hungover and realised what he had done before fitting them
L Lunner Oct 8, 2007 #9 Just take it to a garage then, tbh brakes aren't the thing to be f**king about with if you dont' know what you are doing
ClioGav Car 172 Oct 8, 2007 #11 As lunner said, can be dangerous if you dont know what your doing. Once you've done them a couple of times it's a piece of piss though
MRBILLYUK ClioSport Club Member Car FF Jeden Osiem Dwa Oct 8, 2007 #12 Haz511 said: Still not brave enough Click to expand... It's piece off piss . Have a look at this guide on how to change the pads . http://www.cliosport.net/forum/showthread.php?t=56131
Hazza Car Suzuki Ignis Sport Oct 8, 2007 #13 Popping over to the garage who did my brake pads after work. What should i ask them to do??
pete_clio Car Monaco 172 Oct 8, 2007 #14 to check the pads and make sure there greased up cause its squealing badly
